It is currently Mon Jul 28, 2025 2:34 pm
PostPosted: Sat Oct 31, 2020 12:22 pm
I've been working on my third acoustic and for this one I wanted to use some old piano key ivory a retired pool cue maker friend had given me for christmas some years ago.
I wanted to do a segmented rosette and I went a little further with it and I'm really happy with the results. Just wanted to share my excitement on having completed it. Feels like a big step to do one that's more complicated than just a few continuous lines.
the segments came from the various lengths/widths that I had available. The little black fills are ebony cutoffs from fingerboards. A neat side note is that since ivory is slightly opaque it takes on a slight blue tint when you have a black background. I still have to sand it down and such but it should pop when under some finish.
PostPosted: Sat Oct 31, 2020 12:30 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Looks good! How did you prepare the pieces from the piano key ivory? Did you cut them into arc shapes or is the ivory flexible enough to bend?
PostPosted: Sat Oct 31, 2020 1:10 pm
The pieces had to be cut. Ivory does not like to bend at all I found out the hard way with a test piece. It took some doing to cut them thin enough but it made the glue up much easier.
PostPosted: Sat Oct 31, 2020 1:30 pm
https://www.silversmithing.com/1ivory.htm
Here is a link that includes bending ivory. I believe some old guitars had ivory binding that was bent some way or the other.
PostPosted: Sat Oct 31, 2020 2:26 pm
Your glue is seeping into the grain and leaving a permanent stain.
PostPosted: Sat Oct 31, 2020 2:59 pm
I've bent ivory using naval jelly, which has phosphoric acid as an active ingredient. When using piano key tops for inlay I paint the bottom of the cavity with white paint.
PostPosted: Sat Oct 31, 2020 4:12 pm
Thanks for the info on bending ivory.
Yeah I saw that. I'm not too worried about it. Call it a beginners flaw. I should've sealed the channels a bit better.
I'll try that sometime thanks Clay! I kind of like the blue tint personally so I'm just leaving it on this one.
PostPosted: Sat Oct 31, 2020 4:32 pm
https://umgf.com/how-did-they-process-t ... 42567.html
More techniques
PostPosted: Sat Oct 31, 2020 4:48 pm
wbergman wrote:
https://umgf.com/how-did-they-process-the-ivory-for-bindings-t42567.html
More techniques
Cool thank you for the info. I guess I should amend my original statement by saying I didn't bend the ivory for this and instead cut the pieces to fit. But ivory does in fact bend and can be bent. Guess I should have read more on the topic duh
PostPosted: Sat Oct 31, 2020 9:01 pm
Just as a side note: Some types of ivory can not be sold interstate (Lacey) and some states restrict ivory sales within the state. I will use old salvage elephant ivory on my personal instruments, but if it is something I might sell I'll use bone or one of the "legal" ivories - mammoth, warthog, hippo, wild boar, etc..
PostPosted: Sat Oct 31, 2020 9:53 pm
I'll have to research some on that but that is a good point. There's several folks in my area that make jewelry from the old piano key stuff so I don't know if it's exempt or not. If it turns out to be a problem I'll just remove it and replace it with some white plastic or something.
PostPosted: Sat Oct 31, 2020 10:13 pm
On secind thought. I'm going to scrap this rosette completely and replace the ivory with something like elforyn. Just not worth the potential drama of the real stuff. Oh well.
PostPosted: Sat Oct 31, 2020 10:29 pm
First name: Jay
City: Bothell
State: Washington
You could save it for a guitar you know you are going to keep or put it on a guitar you are going to give away. The drama comes in with a transfer of the ivory involving exchange of money.
PostPosted: Sat Oct 31, 2020 11:26 pm
I wouldn't worry about that little bit of ivory too much. Most people wouldn't know it from white plastic. It's just something to keep in mind when working with some "controlled substances" - ivory, tortoise, rosewoods, etc.
Depending on the state you live in it may be perfectly legal to buy and sell pre-ban ivory within that state.
PostPosted: Thu Nov 12, 2020 6:29 pm
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
That was well stated.
Nice work on your rosette!
Cant wait to see your "elforyn" version with finish on it..... :D
Measure Twice,
Karl Borum
Users browsing this forum: pullshocks and 14 guests
